• 14.11.2026, 09:31
hyperion
D5 NEXT VISION LCD stopped working
Sonntag, 3. März 2019, 22:02
I just installed a D5 NEXT in my pc. The pump is working and the LCD and leds were working but then stopped. I have tried reverting to factory settings in aquasuite but it has not worked. The pump still works.
I managed to get the leds to work again by pushing the control unit tight to the pump body. But then the leds stopped working again and refuse to work even when I try to push the control until tight to the pump body again. It seems to be a faulty connection in the control unit perhaps? What should I do?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »hyperion« (3. März 2019, 22:04)
Montag, 4. März 2019, 13:41
aa1320
Sonntag, 31. März 2019, 15:14
My D5 RGB has lot of issues
- ghost clicking
- random usb disconnection/ re connection
- pump noise ( compare to old aquacomputer D5)
Montag, 1. April 2019, 03:21
What do you mean with "ghost clicking"?
Montag, 1. April 2019, 07:15
ghost clicking
you can disable the touch in the menu.
The pump is exactly the same. There's no difference.
