• 07.10.2026, 16:17
SJGSM
Firmware Update to 1400 RPM for D5 NEXT
Dienstag, 2. April 2019, 21:36
Hello,
I woud like Aquacomputer to provide a FIRMWARE update for the D% NEXT in order to leave the minimun RPM value of the pump to 1400 RPM instead of the default value of 2000 RPM.
I find the default value of 2000 RPM a little bit noisy for me, because I also use the computer for MUSIC LISTENING with my new Audiophile Sound BlasterX AE-9 card.
Could you please AQUACOMPUTER privide a firmware update to set the minimun value to 1400 RPM?
Thank you.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »SJGSM« (2. April 2019, 21:38)
Dienstag, 2. April 2019, 22:17
This is not possible.
SJGSM
Dienstag, 2. April 2019, 22:36
Could you please expand and explain why you say it is not possible?
I believe it is totally feasible. Or maybe it is the Aquacomputer suite , then could you please provide that feature in the new 2019 Aquasuite sofware?
The deafult value of the Old pump was 1400 RPM (good enough for me), but the 2000 RPM is a little noisy.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »SJGSM« (2. April 2019, 22:38)
Mittwoch, 3. April 2019, 07:05
No! The lowest possible value is ~2000 rpm.
When you hear noise from the Pump you have to select a better top : https://shop.aquacomputer.de/product_inf…roducts_id=3786
or decoupe the pump in a better way.
