• 10.10.2026, 11:43
arntorrus
Aquaero is blocking the turning off display of PC monitors
Sonntag, 5. Mai 2019, 13:54
After plug-in Aquaero 6 XT USB connection Windows 10 doesn't turn off displays.
When I disconnect USB cable, the turning off is begining working fine.
How can I solve this problem?
UPD: I found Aquaero on Windows 10 "Bluetooth and other devices" menu. If delete this equipment the turning off work fine. But OS install this device in each start. And after deleting, the Aquasuite don't see Aquaero.
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »arntorrus« (8. Mai 2019, 13:49)
arntorrus
Dienstag, 7. Mai 2019, 11:19
UPD: The reson was is software from GIGABYTE, Aorus Engine
The problem is gone.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »arntorrus« (8. Mai 2019, 13:49)
