• 06.11.2026, 19:38
Warmaniac_209
Quadro Voltage control ?
Samstag, 1. Juni 2019, 09:52
i recently bought a aquaero 6 for my build, and i wondered if it where any means to add more fan channel, like with a Quadro, but not necesarly PWM, ive got 5 fan group and 2 pumps, and i would like to get everything back on the aquaero, 4 of my fan group are gentle typhoon 1850 RPM fan, so they work on voltage control, 1 fan group is gentle typhoon high RPM 4250 RPM, PWM controlled, and 2 EK-D5 Pump, PWM controlled, set in redundancy, if one pump fail, the aquaero switch to the other. Right now, my two pumps are connected on fan header 2-3, one header each, and my High RPM gentle typhoon are on fan header 1 with a splitter, everything is controlled by PWM, ive got a spare header here, but i want to add my others fans group, is the Quadro suited for controlling Voltage regulated fan like the Gentle typhoon 1850 RPM or not ? i know the aquaero 5 LT can do this.... but i would find this wasteful i would really not use it to its full potential....
Thanks
RE: Quadro Voltage control ?
Montag, 3. Juni 2019, 11:39
No, only PWM fans
