• 12.11.2026, 03:31
INACIO JUNIOR
The device has USB
Samstag, 29. Juni 2019, 17:46
All cables are connected, including USB, and I'm getting this message.
::.I7-10700k 5.1 Ghz | Asus Maximus XII Formula | GTX 1080 Ti ASUS POSEIDON.::
::.32GB Corsair Dominator Platinum RGB 3000 Mhz | WaterCooler Custom.::
::.Teclado MadCatz S.T.R.I.K.E.7 | Mouse M.M.0.7.::
::.2X SSD HyperX Savage x 250GB RAID0.::
::.Fonte Corsair AX1200W | Cosmos II.::
Samstag, 29. Juni 2019, 18:36
your windows is not able to detect the usb device.
this is an usb or windows problem.
INACIO JUNIOR
Samstag, 29. Juni 2019, 21:40
What should I do?
Sonntag, 30. Juni 2019, 13:30
Are you using a USB hub? if so, try direct connecting to the motherboard for a test.
Also, be sure the polarity of the USB cable connectors is correct on both ends.
The PSU powering the motherboard is the same one powering the aquaero (same PSU for both)?
INACIO JUNIOR
Dienstag, 23. Juli 2019, 08:13
Ok, problem solved, thanks. ;)
