• 03.11.2026, 01:22
montego
Adding two D5 Next
Dienstag, 16. Juli 2019, 05:45
Hello,
I am trying to add two pumps. One pump is connected to motherboard and is available on aquasuite and all works fine. Second pump shows connected to my aquaero's aquabus port and shows as connected but does not appear on the control menu. How do I add the second pump so I could control both pumps? Thank you.
»montego« hat folgendes Bild angehängt:
Dienstag, 16. Juli 2019, 08:09
only via USB connected devices has a own device entry in the aquasuite.
you have to connect both pumps via usb.
bojer
Mittwoch, 17. Juli 2019, 11:12
I have same problem...
so if I want allways access to D5 Next config so must be allways connected over internal USB?
Connection only over HIGH port on aquareo providing only informations from availabled sensors on pump?
montego
Mittwoch, 17. Juli 2019, 22:45
I cant connect via my aquero aquabus ports?
Donnerstag, 18. Juli 2019, 06:47
