• 16.11.2026, 17:59
knacker
AE6 and Corsair pump question
Dienstag, 13. August 2019, 22:51
Can anyone let me know if I plug the 4 pin cable from a Corsiar RGB pump into a fan header, will it allow me to control the pump speed like a fan effectively? Power is coming from molex also but was just wondering if it could work as well
Thx ;( :D
Hufeisen
Dienstag, 13. August 2019, 22:59
Corsair has a lot of pumps... which Model is it exactly?
knacker
Dienstag, 13. August 2019, 23:37
It's the new XD5 rgb thingy- says it has a D5 pwn pump 8|
Hufeisen
Mittwoch, 14. August 2019, 20:27
You can connect the Corsair D5 Pump to the Aquaero 6, but it is possible that you cant control the Pump with the PWM Signal.
The reason is that the D5 pump PWM Signal does not comply with the Aquaero PWM Specifications.
If you cant control the pump, you need to modify the Connector and add some resistors.
Read this post how to do it: https://www.overclock.net/forum/61-water…ml#post22946282
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hufeisen« (14. August 2019, 20:44)
GTXJackBauer
Donnerstag, 15. August 2019, 00:39
+1
