• 12.11.2026, 19:30
eol
aquasuite will not run
Donnerstag, 5. September 2019, 18:34
it seems to have stopped working after the latest update to windows 10 service pack
Donnerstag, 5. September 2019, 20:41
When you have running rivatuner RTSS this is the problem, not the aquasuite.
You have to add a excetiption rule in RTSS.
eol
Donnerstag, 5. September 2019, 20:45
you are right it was riva tuner issue, its strange because i had both set to turn on with startup but aquasuite stopped booting after the patch, now it crashes when ever riva tuner is on, is there something i can do to fix this?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »eol« (5. September 2019, 20:47)
Donnerstag, 5. September 2019, 21:17
it is an issue with the kb4512941 update and RTSS.
selvakumar1989
Montag, 9. September 2019, 12:13
Hi how to add a excetiption rule in RTSS
selvakumar1989
Montag, 9. September 2019, 12:18
I cant open the setup after the latest update
selvakumar1989
Montag, 9. September 2019, 13:04
please follow the guide and it works like lucky charm
https://www.tenforums.com/pc-custom-buil…urners-osd.html
