• 14.11.2026, 23:31
JoeDorson
Mounting Aquaero XT screen externally.
Samstag, 14. September 2019, 17:22
I tried searching the forums and got no hits so I hope I am not repeating something obvious.
My case unfortunately has 0 accessible 5.25 drive bays. I am planning to purchase a Aquaero 6 XT and separate the screen assembly and the actual control board, make a cable to join the lcd/controls and then fabricate some kind of stand alone mount so I can position the display part somewhere else, although I haven't decided exactly where yet.
Is there any technical reason why this wouldn't work?
Thanks for any insight,
Joe
Sonntag, 15. September 2019, 03:28
aquacomputer has a short (≈150mm) extension they use on the airplex GIGANT to mount the display off the aquaero.
Send an email to support at aquacomputer.de for details.
JoeDorson
Sonntag, 15. September 2019, 18:23
Thanks, I will drop them a line :)
Joe
fragilityV1
Montag, 4. November 2019, 20:00
Did you get this resolved? I was thinking of going a similar route.
