• 29.11.2026, 11:19
GTXJackBauer
Montag, 14. Oktober 2019, 02:09
Just wow. That's one heck of a external system you got there. I'm guessing you use QDC's to your rig? Some pics would be nice of that as well. :D
4WDBenio
Montag, 14. Oktober 2019, 15:17
Well... I was almost going to just stick with the Pwm D5 Pumps....but now the launch of a Playground https://forum.aquacomputer.de/weitere-fo…-aquasuite-x-5/
.... DOES that bring the value back to taking on the D5 Next Pump :?:
Montag, 14. Oktober 2019, 20:49
I used the Alphacool Eiszapfen HF quick release connector kit G3/8 inner thread with reducing nipple G1/4.
They are large, but since they are external it doesn't matter, and allows better flow.
Montag, 14. Oktober 2019, 21:08
For me, personally, it would not. I was initially awed by the D5 NEXT when it was released, but it is more bulky than the D5 PWM, and there is no cost advantage. What I mean is, the (D5 Next) = 119,90 and the (D5 PWM @ 74,90 + QUADRO @ 39,90) = 114,80, with more fan ports and fan curve controllers.
It depends on YOUR build and YOUR preferences.
