• 06.11.2026, 13:23
apistodave
Aquasuite
Freitag, 10. Januar 2020, 23:01
I cant get it to do anything. I can get green or blue on any of my three strings but that's it. I;ve got all of them set to presets and it just doesn't work like it should. I can try any of the other oprions , but they either just go out completely, or---Blue.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »apistodave« (10. Januar 2020, 23:02)
Samstag, 11. Januar 2020, 04:27
We need to know which devices you have, and some screenshots of the setup tabs so we can see where you are.
apistodave
Samstag, 11. Januar 2020, 19:45
I have one farbwerk with about 20 feet of aquacomp lights---I have another controller on the way
»apistodave« hat folgendes Bild angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »apistodave« (11. Januar 2020, 19:49)
Samstag, 11. Januar 2020, 20:04
The strip is doing what you have programed it to do, show Blue.
GTXJackBauer
Samstag, 11. Januar 2020, 20:25
Careful with the amount of lights used on each channel and in total on the Farbwerk unit.
apistodave
Samstag, 11. Januar 2020, 21:05
ok SO THIS IS CHANNEL 3 WHICH HAS ABOUT 8 FT OF LIGHTS--i HAVE IT ON red but the lights are blue--I'm thinking I have too long a string on this--do you concur?
GTXJackBauer
Samstag, 11. Januar 2020, 23:12
Maybe I'm wrong here but it could probably be because it's protecting itself if you haven't damaged it yet.
Read this below taken from the site.
Comaptible LED strips:
LED strips for 12 V, common anode. Suitable LED strips and connectors are available from Aqua Computer.
Maximum current per channel: 2,5 A
Maximum combined current (all channels): 8 A (resulting in a maximum total power of 96 Watts at 12 Volts)
apistodave
Sonntag, 12. Januar 2020, 00:03
I think I have loo many I'm going to make some changes. How does one calculate the wattage?
