• 01.10.2026, 14:24
vils
bent tubing
Mittwoch, 15. Dezember 2004, 17:23
When my airplex evo 360 arrived today I found that both the inlet and outlet tube was bent so tightly towards the radiator edge that it was impossibly to screw down the hose connectors.
I suppose it would be easy to adjust this by a firm twist from a polygrip plier.... but would this void the guarantee?
Do you have any suggestions?
Thanks in advance.
/Vils
All work and no play makes Jack a dull boy.
Nitrix
Re: bent tubing
Mittwoch, 15. Dezember 2004, 17:45
Thats a hard one.....
If it was me id try and bend it back, mainly cos i couldnt be bothered to send it back 8)
pharao
Re: bent tubing
Mittwoch, 15. Dezember 2004, 17:52
bend it back VERY carefully.
don't use a tool. only with your hand. (language question: "just with your hand" or "only with your hand"??)
good luck ;)
Bluefake
Re: bent tubing
Mittwoch, 15. Dezember 2004, 17:55
@ hobbes_dmS
Your second suggestion was the right one.
pharao
Re: bent tubing
Mittwoch, 15. Dezember 2004, 17:56
or "with your hand, only" ... :D
vils
Re: bent tubing
Mittwoch, 15. Dezember 2004, 20:38
Thanks, I'll try to bend back the pipes gently, by hand only :)
vils
Re: bent tubing
Mittwoch, 15. Dezember 2004, 20:40
Worked smoothly..
NikoMo
NikoMod
Re: bent tubing
Donnerstag, 16. Dezember 2004, 21:46
Zitat von »vils«
Worked smoothly..
congratulations. you lost all your guarantee. ;D (just joking)
when you bend it slightly, it's no problem with the guarantee or waranty. it won't be void.
kampfsau
Re: bent tubing
Freitag, 17. Dezember 2004, 00:22
yeah... but if you´re some kind of king-kong impersonator and rip off the tubing right out the radiator, then you should start worrying about warranty...
just a litte ;D
