• 14.11.2026, 16:15
JohnAMcG
Please Help. I fried Two d5 Next Pumps.
Samstag, 18. Januar 2020, 23:05
I have an AX1200i power supply and I did not realize that they use a proprietary 6 pin connector on the SATA power cables. I had normal SATA power cables connected to my pumps. Everything brand new. I was setting up a test loop so I can set up the aquaero and run some tests before starting my build. I have a lot of AC gear to get set up with all the bells and whistles. Long story short, the cable put the wrong volatage on the wrong pins and I fried both of my D5 NEXT pump bases.
Is there any way to purchase the D5 NEXT base separately? I have been purchasing my aquacomputer products from Amazon and Aquatuning.us Please help, I have never even gotten to see the pumps run. -JM
Samstag, 18. Januar 2020, 23:14
Send an email to support@aqua-computer.de. They will help you.
JohnAMcG
Samstag, 18. Januar 2020, 23:41
Thank you for your advice. I have now emailed support as you suggested.
