• 18.11.2026, 05:27
kschermers
D5 Next System Alarms on PC Sleep/Shutdown
Montag, 3. Februar 2020, 08:21
I have my system up and running with a D5 Next, but whenever I power down my PC, I get a '12V out of range' / '5V out of range'/'pump speed too low' system error from the pump. My understanding is that mobo is still supplying power via usb when system is powered off.
I have a Gigabyte Auros Z390 Ultra mobo. I already tried enabling 'ErP' in the bios but that did not fix my issue. Thanks for your help.
Montag, 3. Februar 2020, 08:59
When you power off your system normaly the SATA connector has no Voltage, (5V = 0, 12V = 0).
The USB Standby is not used.
Is your Pump off when you unplug the SATA power connector?
I think this is a issue with your Mainboard or PSU.
kschermers
Montag, 3. Februar 2020, 16:29
Yes, the pump depowers when i unplug sata. I realize its not an issue with the D5 itself, but most likely my mobo supplying power to usb devices even in a power off state. is there no fix for this on the pumps end? no way to disable the system alarms? I realize its not recommended but im not sure what else would fix it
Hufeisen
Montag, 3. Februar 2020, 18:31
If you unplug the USB Cable from the pump, do you still get an Alarm?
If yes, then the problem is the Power Supply providing +5V even if the Mainboard is turned off.
GTXJackBauer
Dienstag, 4. Februar 2020, 01:41
There should be a EU or green energy feature that shuts off 5V completely when the system turns off. Should be in your BIOS. I had an issue where my AQ6's display would still be on but once I enabled EU standards in my BIOS, nothing is powered on anymore.
kschermers
Dienstag, 4. Februar 2020, 04:02
unplugging USB solves the issue so yes it is a mobo/BIOS issue i think. something i saw in reddit said to enable 'ErP' setting in my BIOS (Gigabyte), but even after i enabled that I still get the problem. i poked around but didnt see any other settings that may relate to usb power, will continue searching. might try updating BIOS. ?(
xOperator
Mittwoch, 5. Februar 2020, 17:13
I have an ASUS and have ErP disabled.
I remember on my older ASUS motherboard, I had that problem with another USB device staying on. It had to do with some kind of Fast Charge USB port option it had for charging mobile devices.
When i powered off, that usb port was still supplying power.
Do you have a similar usb charge port feature?
