• 12.11.2026, 18:30
smud
kryoM.2 difference between two water blocks
Montag, 17. Februar 2020, 00:50
https://shop.aquacomputer.de/product_inf…roducts_id=3401 <- which plated this one?
https://shop.aquacomputer.de/product_inf…roducts_id=3408 (nickel plated water block)
I didn't find information about https://shop.aquacomputer.de/product_inf…roducts_id=3401 , seems it's copper by images but I wonder why it's cheaper than nickel then? I though copper has better heat sink than nickel or?
Montag, 17. Februar 2020, 05:08
I believe both are copper, the nickel version has a nickel plating applied, hence the additional cost.
smud
Montag, 17. Februar 2020, 15:39
Isn't it pointless to do then - adding nickel over copper since copper has better heat sink? 8| ?(
eisbehr
Montag, 17. Februar 2020, 15:55
Some like silver plated coolers more than a copper surface. ;)
And the plating protects the copper for oxidation.
Montag, 17. Februar 2020, 16:47
What eisbehr said... plus, the heat transfer lost across the very thin nickel layer is minimal.
But, for the purist, aquacomputer does provide the naked copper option.
Many people have paint on their radiators, not an optimal solution, but an aesthetic trade-off.
It's all about personal preferences, capitalism at work :)
Hufeisen
Montag, 17. Februar 2020, 18:08
Nickel plating is required if you want to use Liquid Metal as thermal paste.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hufeisen« (17. Februar 2020, 18:10)
eisbehr
Montag, 17. Februar 2020, 18:25
As we learn step by step, everything is there for a reason! :D
smud
Montag, 17. Februar 2020, 18:54
I don't think what you can apply liquid metal for these M.2 water blocks :D
