• 02.10.2026, 02:24
stingray
aq 5/6 farbwerk question
Montag, 24. Februar 2020, 04:20
ill be connecting an a5 an a6 and a farbwerk together
must i only use the high aquabus to do this which will require a splitty or a 3 way cable or can i use the low aquabus to connect them
thanks in advance guys
stingray
Dienstag, 25. Februar 2020, 04:18
whomever is kind enough to explain this connecting concept gets a big hug. :thumbup:
Dienstag, 25. Februar 2020, 05:17
lol.
Low aquabus has been removed... the old low aquabus port on the aquaero is now a flow sensor port.
Even if you have not updated the firmware on the aquaeros, the low aquabus was for a couple of now eol devices.
Bottom line, NO low aquabus, especially not for the farbwerk.
