• 16.11.2026, 22:16
Netherspark
I don't understand "RGBpx"?
Montag, 24. Februar 2020, 21:27
Can someone explain what "RGBpx" is please, and how is it different to standard 5v A-RGB?
I'm looking at getting a Quadro and would like to use the RGB controller, but none of it makes any sense to me. For a start the product page says it can control 4-channels of addressable RGB strips/fans, but it only has one header. And it's a 4-pin at that.
And is it supposed to be compatible with standard 5v A-RGB devices, like a Phanteks LED strip for example? Or is it all a proprietary system that only works with their own strips?
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »Netherspark« (24. Februar 2020, 21:36)
eisbehr
Montag, 24. Februar 2020, 21:42
RGBpx is basically just a product name for the own connection type. There are adapters for connection default componentes to RGBpx of even to connect RGBpx to standard mainboard header:
https://shop.aquacomputer.de/product_inf…roducts_id=3829
https://shop.aquacomputer.de/product_inf…roducts_id=3831
And with a splitty, you can even directly connect Corsair or NZXT products as well:
https://shop.aquacomputer.de/product_inf…roducts_id=3766
But the Quadro has only one RGBpx channel for up to 90 LEDs. It hast four PWM Channels. Maybe you messed this up?!
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »eisbehr« (24. Februar 2020, 21:46)
Netherspark
Montag, 24. Februar 2020, 21:51
Right, so it is a totally proprietary connection that only works for their own products, and you need adapters to make it compatible with other types?
Multiple retailers say it has 4 RGB channels on the product page. Maybe this is a mistake... here's the quote, same from OverclockersUK and UKwatercooling:
"The four RGBpx LED outputs can be used to connect AquaPC's corresponding RGBpx strips and can also be controlled via the software"
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Netherspark« (24. Februar 2020, 21:55)
eisbehr
Montag, 24. Februar 2020, 22:06
Only the four-pin connector is proprietary, behind that it seems just argb.
Quoted
It seems the text belongs to the Farbwerk360, wich has four RGBpx Channels/Connectors. The Quatro has one Channel and the Octo hast two channels.
Hufeisen
Montag, 24. Februar 2020, 23:09
RGBpx is compatible with all "WS2812" LED. That is the most common adressable LED Standard.
The Connector is Molex Picoblade.
RGBpx has some Limits:
- maximum 90 LEDs on a RGBpx Channel
- all LEDs on a channel need to be chained in a row. If you want to connect 2 LED strips, you need to place a wire between the end of the 1st strip and the start of the 2nd strip.
You can set different effects on a RGBpx channel in the Aquasuite software. (for example: LED number 1-33 get effect X, LED number 34-55 get effect Y)
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »Hufeisen« (25. Februar 2020, 00:05)
