• 06.10.2026, 00:41
GetSchwiftyClub
USB 2.0 Question (Quadro & D5 Next)
Dienstag, 31. März 2020, 01:17
My Motherboard has a 9 pin USB 2.0 header (Two Ports) and my question is: Will that 9 pin support both a Quadro and D5 Next properly?
My Front Panel I/O only has USB 3.0 ports so I don't necessarily have a use for the USB 2.0 header.
Dienstag, 31. März 2020, 14:20
Yes. Connect both items items directly to the motherboard's USB 2.0 terminal with their included internal USB cables. (Polarity counts)
GetSchwiftyClub
Mittwoch, 1. April 2020, 01:07
Thank you for the response! I have a Hubby7 but it might be overkill since I wouldn't have a use for the other 5 available ports on the Hubby.
