• 12.11.2026, 17:50
Spirti1976
RGBpx splitty 4 question
Samstag, 18. April 2020, 17:01
Hey everyone, splitty 4 has a regular 5V RGB header (named ASUS on the board), so do I get it right - if I plug regular addressable RGB strip to it I can get the RGBpx effects on it? Or do I need anything else? I have both Farbwerk 360 and D5 NEXT. Manual says only about Corsair and NZXT and nothing about that ASUS header.
Thanks in advance.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Spirti1976« (18. April 2020, 17:27)
Hufeisen
Montag, 20. April 2020, 21:13
You dont need a Splitty4 if you want to change RGBpx Connector to ASUS Connector.
This https://shop.aquacomputer.de/product_inf…roducts_id=3829 is enough.
You need to buy a RGBpx Cable to connect the Adapter to the RGBpx Port on the Quadro, D5 Next or Farbwerk 360
https://shop.aquacomputer.de/product_inf…roducts_id=3763
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Hufeisen« (20. April 2020, 21:17)
Spirti1976
Montag, 20. April 2020, 23:08
Oh, I see, didn't notice that thingy. Thanks!
