• 16.11.2026, 06:17
Dundys
Removing display from Aquaero 6 XT
Freitag, 24. April 2020, 19:49
I have Aquaeros 6XT and I'm considering taking the display off to fit the unit hidden inside the case , will there be any limitation in functionality, am I going to lose more then just a display:)
Thanks
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »Dundys« (24. April 2020, 20:01)
Freitag, 24. April 2020, 20:14
Can be done without problems but do it after you have used the device at least one time with the aquasuite software so that your runtime for free updates is set for a XT device. If you do this afterwards you will only get the shorter runtime of a LT device. Please note that this is a one time thing and stored online in a database. There is no need to save your aquasuite folder etc. If you install the aquasuite again it will still have the longer runtime for updates because this information is bound to the serial number of your aquaero main controller board.
Dundys
Freitag, 24. April 2020, 20:24
Thank you for your prompted response, considerations taking :thumbup:
