• 11.10.2026, 01:45
Ujin
Vision Touch not detected
Freitag, 15. Mai 2020, 16:10
I've just got a Vision Touch table top ( 53238 ), but I can't seem to get it to work.
I plug it to any of the computer's USB ports and it powers on, but the only thing I can see is the Vision logo. I can go into the settings as well, but cannot see any pages.
It doesn't appear in Aquasuite (X.17) and Windows doesn't seem to see anything as plugged in. Other USB devices work fine and Aquasuite does see and control my D5 Next and my Quadro normally.
Any ideas? Do I have a faulty unit?
Thanks!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Ujin« (15. Mai 2020, 16:19)
Freitag, 15. Mai 2020, 16:39
then the device has no active USB connection. Check the device with a other computer
Ujin
Freitag, 15. Mai 2020, 18:17
Thanks for the reply. I think the cable might not be making a good connection with the Vision unit itself. I pushed it a bit at the vision end and it started working properly.
