• 08.10.2026, 08:13
lhdrive
since X.23, unable to save more than one profile into Octo
Mittwoch, 22. Juli 2020, 04:51
Using Octo, MPS USB and Farbwerk 360
can only save one profile now since X.23 update
Donnerstag, 23. Juli 2020, 09:24
No problem here, works as it should.
Maybe the background service was not active or crashed when you tried to set up a profile.
lhdrive
Further feedback
Montag, 27. Juli 2020, 02:38
Hi Shoggy
Thanks for checking
I'm still having problems as follows:
I've set up profiles and saved them
On restarting (after full shut down) Aquasuite isn't showing these updates.
I stop the service, restart it, shut down Aquasuite and the service and restart both apications and the profile now return
In summary, they are saving, but it's quite the process to have them return
Dienstag, 28. Juli 2020, 09:16
Please try to raise the delay for the start start of the Aqua Computer service. Maybe try 8 seconds for example. Of course you will also have to wait this time after a system start before the profiles will be available.
