• 10.10.2026, 16:00
helis4life
Farbwerk Nano - Leds 46 - 60 showing slightly different colour and flickering
Sonntag, 2. August 2020, 14:51
Hello,
I have a farbwerk Nano with 5 Aquacomputer RGBpx strips (53268) connected for a total of 75 leds. When all set to a fixed colour it is apparent
that leds 46 - 60 are a slighly warmer colour. I thought it was the strip and so bought a replacement, installed but it shows the same issue. The leds 46 - 60 are also
flickering. LEDS 61 - 75 are the correct colour and do not flicker
The nano firmware is the latest and aquasuite is the latest version
I tried to perform a reset in aquasuite but problem still persists
Is this a fault with the farbwerk nano controller?
Thanks
helis4life
Montag, 3. August 2020, 23:36
No one can offer any help with this? Do I need to RMA my nano?
Dienstag, 4. August 2020, 07:17
Check all you cables and wiring. Ensure your usb port can supply enough power. Limit the global brightness in the System tab to 50% and check if the behavior is changed.
