• 03.10.2026, 07:19
mysthik51
aquasuite x25 and aida 64 issue
Dienstag, 18. August 2020, 09:11
Hi, i have finished to install the aquasuite x25,but since that, i can't choose AIDA 64 sensors,from the controllers, and so, the system go to max speed,since that. have you that problem ? how can i solve this,please ?
Dienstag, 18. August 2020, 09:20
Have you selected the sensors in AIDA that you want to export?
Did you update from an old aquasuite version?
a few more informations please. Your devices? System, ....
It does not work is not a sufficient error description.
mysthik51
Dienstag, 18. August 2020, 09:22
Hi Sebastian. Yes,with the older aquasuite version,it was good,and functionnally. but,i was update with that older version,and the aida sensors doesn't appear in the aquasuite. yes, the aida sensors is active
Dienstag, 18. August 2020, 09:27
No one can help you like this.
Write down everything you did to solve the problem.
Please describe everything exactly, including version number (firmware, aquasuite etc.) Windows?
Aida is working with the newest aquasuite (X.25)
mysthik51
Dienstag, 18. August 2020, 09:32
ok,so :
it was be update from the older version before x23 ( -> x21 ? ) to x25
aquaero firmware : 2104
aquastream 1018
for the os,it's windows 10 home 64 with aida 64 extreme 6.25.5400
with the old aquasuite , in the software temperature sensor on the aquero menu, aida was appear, for choice the sensor for CPU and VRM, but since the x25, it doesn't appear.
do you wan't an other information ?
Dienstag, 18. August 2020, 09:35
Did you see the Service data in the Quick View tab?
Post some Screenshots from the aquasuite.
Try to Disable the aquasuite hardware monitor and restart you system.
mysthik51
Dienstag, 18. August 2020, 09:43
so, it doesn't appear in quick view, but i have stop service,and restart service how you say,and it appear finally.
in screenshots, beforce stop and go service.
finally,all some like ok. thank's for all
»mysthik51« hat folgende Dateien angehängt:
  • 2.jpg (129,88 kB - 114 mal heruntergeladen - zuletzt: 27. September 2026, 10:27)
  • 1.jpg (215,38 kB - 137 mal heruntergeladen - zuletzt: Heute, 00:46)
