• 12.11.2026, 04:13
stingray
aquaero temps
Samstag, 29. August 2020, 00:29
hi
how do you determine the temp that the aquaero is running at?
thx
stingray
Samstag, 29. August 2020, 02:33
17 views,,looks like im not the only one that dont know where to read the actual temp of the aquaero itself :thumbsup:
Samstag, 29. August 2020, 03:58
stingray
Samstag, 29. August 2020, 05:23
i wouldnt think these are whats used when controlling the temp of the actual aquaero when water cooling it.
in older software all 4 couldnt be used
Samstag, 29. August 2020, 10:19
So my AE5 has 2 temperature sensors, fan amplifiers 1 & 2 and 3 & 4.
I'm not sure if I understand your question
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »EnigmaG« (29. August 2020, 11:16)
Samstag, 29. August 2020, 15:31
The only direct control you have, is if do NOT controll the fans using the PWM mode.
In that case you could set a Controller Curve to increase fan speed as the Fan Amplifiers increase in temperature. vss_sample.jpg
Note to aqaucomputer: it would be useful to have more than two inputs for the Max/Min functions
