• 10.10.2026, 07:17
oivind_stenvik
RGBpx and LED fans (corsair QL fans)
Donnerstag, 10. September 2020, 22:30
RGBpx can have devices with total of 90 led on once channel
Corsair QL fans have 34 leds each fan -> max two of these on one RGBpx channel -> 2 x 34 = 68 leds
max 90 leds - 68 leds on fans = 22 free to be used by other devices ? (If using splitty4 one might have to diy an connector to rgb port 3 and 4 that somehow finish corsair 'loop' before add more leds to this channel ?)
Question -> can one connect ledstrip 22 leds on same channel as fans -> total 90 leds. How to manage this about connection?
RGB LED 5 mm for RGB splitty3 -> what happens if have led strip desolder one led on ledstrip and solder this 5 mm to led strip and thus use it with RGBpx devices ? Doable? Need 6 x rgb leds for aqua watertank.
stenvik
Hufeisen
Freitag, 11. September 2020, 14:38
Yes, this is possilbe, if the LED Strip is compatible with RGBpx System (The LED Strip must use WS2812B LEDs).
You have to solder a diy Connector to RGB Port 3 on the Splitty4.
This is a analogue 12V LED, and is NOT compatible with the RGBpx System.
RGBpx requires Digital adressable 5V LEDs compatible with WS2812B Standard.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Hufeisen« (11. September 2020, 14:42)
oivind_stenvik
Freitag, 11. September 2020, 18:06
Was thinking about to replace one of leds on compatible led strip with "RGB LED 5 mm for RGB splitty3"
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »oivind_stenvik« (11. September 2020, 18:08)
oivind_stenvik
Samstag, 12. September 2020, 19:33
Found an RGB adressable 5V LEDS 5 mm that can be used -> https://smdua.in.ua/image/pdf/WS2812D-F5.pdf
should be compatible with WS2812B standard
anub1s21
Samstag, 3. Oktober 2020, 19:41
i had a question tying in to this question.
could you use a different corsair RGB fan for the remaining 22 controllable led's (like a LL or ML) as well then?
i was under the impression you connected 1 type of device and can't or shouldn't mix fan types (2 QL and a LL, or 2LL's or a QL), please do say if i'm mistaken.
