• 29.11.2026, 03:15
Flop Ysh
Would the Ryzen optimized waterblock works also for Zen3
Donnerstag, 8. Oktober 2020, 22:58
Hello
At first glance, it seems that the layout of Zen3 is the same as Ryzen Zen2. So the 3000 optimized waterblocks are perfectffor 5000 serie also.
Does anyone confirm?
Freitag, 9. Oktober 2020, 08:00
the kryos NEXT with the name "AM4/3000" has the Optimized mounting position, without the "3000" the Cooler ist centered.
All Waterblocks with a AM4 Mount works with all AM4 Processors.
https://shop.aquacomputer.de/index.php?c…350&language=en
Flop Ysh
Freitag, 9. Oktober 2020, 14:29
Hallo Sebastian
Thanks but Let me rephrase
I know that every waterblock/ventirad that has a AM4 mounting mechanism will be compatible with that Zen3 gen.
It seems that the Zen3 layout is the same as Ryzen one. So can someone confirm that the Zen3 CPU's will also get better cooling with your am4/3000 serie waterblocks?
Ps : I spotted a "ist" in your sentence :D
Freitag, 9. Oktober 2020, 15:15
The positioning of the Ryzen 5000 CCDs on the interposer is the same as on the Ryzen 3000 CPUs, the TDP is also identical, so one can assume more or less the same cooling capacity of the water blocks on Ryzen 3000 and 5000.
Flop Ysh
Freitag, 9. Oktober 2020, 15:55
Thanks for sharing your analysis, therefor confirming mine
