Du bist nicht angemeldet.
I guess they just think that not much of D5 NEXT's buyers also have aquaero, and not much aquaero buyers buy a D5 NEXT. So the cable is optional - remember it is not requred to operation, it adds functions. It's up to you to forward think, what options do you want to use and thus what cables you gonna need.I guess they figure no one with a A5 or A6 will want to use aquabus? It sounds interesting at least.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »k2viper« (22. Oktober 2020, 21:23)
There is a simple explanation, the Aquabus is only necessary if you want to use the data from different devices, in a non-Windows environment, as input to the Aquaero or control the devices directly from the Aquaero.The pump came today and no aquabus cable and the one that came with the A6 don't fit. For $55 more in shipping I can order the $3 cable. Would be nice if a aquabus device came with one. I guess they figure no one with a A5 or A6 will want to use aquabus? It sounds interesting at least.
"What it actually does, is making D5 NEXT's own Fan channel accessible to control via advanced aquaero's controllers, and makes pump control available via aquaero Pumps tab."
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Tanquen« (24. Oktober 2020, 19:13)
You don't pay any extra for the LEDs or the display, the D5NEXT is a complete product, you can't leave anything out, who doesn't want it buys another pump!"Why should 90 + % of the users pay more for a product to get a cable that only 10% of the users need?"
I hear you but it is ok for 100% to pay more for LED, Display and controls? But it's not ok to put a 1$-ish cable (or proper protection/packaging) in the box of the $125-ish pump?![]()
