• 20.11.2026, 06:04
KaJ
Fan Controller Delay Possible? Stop fans from ramping up and down on Ryzen
Samstag, 24. Oktober 2020, 19:00
So I'm using this software for an air cooled PC right now. I use a virtual CPU/GPU max temp to control most of the fans. However, Ryzen spikes quite a bit into the 70-80*C range and then goes back down to 40-50*C almost immediately. When using my mobo software I just set a fan delay of 2 seconds, so once it hit 70C it would have to hold it for 2 seconds before the fans responded. This meant the fans never kept ramping up and down since it only holds 70*C for a split second. Is this possible to do something similar in Aquasuite X? I am using an Aquaero 6 and a Quadro.
k2viper
Samstag, 24. Oktober 2020, 19:04
Use Average(t) and Low pass filter functions in Playground.
KaJ
Samstag, 24. Oktober 2020, 19:23
Nice, didn't even know this area existed. Low pass time span lowest time is 5s, seems a little long. No way to lower that value? Also what does the damping number do, can't really tell when I move it up and down (range 0 to 100).
k2viper
Samstag, 24. Oktober 2020, 19:45
Damping is "strength" of smoothing.
Try Average(t), it may have lower then 5s time.
mattlach
Sonntag, 25. Oktober 2020, 00:11
I had this issue with one of my pumps.
I just configured a minimum pump speed, and I never had the issue again.
