• 10.10.2026, 23:34
mattlach
Controlling Two (or more) Aquaero's Not in Master/Slave mode from Aquasuite?
Sonntag, 25. Oktober 2020, 00:10
Hey all,
Just wondering if anyone knows how this would behave.
I am considering doing a little bit of an unusual multiloop setup (CPU & GPU on one loop, Radiators on another, coolant mixing in reservoir) bit it will wind up needing more PWM and Aquabus connections than are available on one Aquaero.
Luckily I have a spare Aquaero sitting around, so I figured I'd hook them both up, but use both as masters with no slave device.
Does anyone know if the Aquasuite software handles multiple units like this gracefully?
Can I map sensors from both units to the same graphical dashboard?
Much obliged,
Matt
Montag, 26. Oktober 2020, 07:18
the aquasuite can handle multiple devices.
you can create you own dashboards/over pages and use the data dources from all available devices/sources.
Omnipotous
Freitag, 6. November 2020, 20:39
yup i have 2 XT pro aquaro 5's and 1 Aquaero 6 XT
12 Power relays for three cooler banks
2 D5 Next Pumps
2 Farbwerk's
1 farbwerk 360
and 2 Hubby 7s. to USB them all
the Dual Power supplies had just enough Molex connectors and a few extensions
Monster Build.
