• 27.11.2026, 01:10
ND1
ULTITUBE D5 150 PRO with D5 Next pump - RGBpx and Aquasuite connection
Donnerstag, 29. Oktober 2020, 19:34
Hello. I'm planning overall setup scheme and can't manage how to handle RGB control for D5 Next and Ultitube reservoir.
For example - can I use my Octo's RGBpx output and single RGBpx cable for simultaneous reservoir ring and pump RGB control? Or ring and pump also should have additional RGBpx cable between them?
Also, do I need Aquaero to have pump and it's RGB settings shown in Aquasuite? Or I can just connect my Octo by USB to motherboard and Aquasuite will have all devices?
Thanks.
k2viper
Donnerstag, 29. Oktober 2020, 21:53
D5 NEXT has its own 90-led RGBpx channel and thus can be solely used to control ULTITUBE led ring.
You do not need aquaero to control RGBpx, aquaero do not support it.
You connect OCTO and D5 NEXT to USB and have all controls available.
