• 13.11.2026, 01:28
cmsj
Execute commands on profile change
Dienstag, 3. November 2020, 13:37
Hi folks!
Is it possible to get Aquasuite to execute a command when a profile is changed? (either through an automatic rule, or via the system tray selector)
I have different RGB settings for different profiles, and it would be nice to be able to tell OpenRGB to switch motherboard/ram/keyboard/mouse RGB settings when the aquasuite profile changes.
If this isn't a feature already, could it be added?
Many thanks!
Chris
Dienstag, 3. November 2020, 13:55
You can use the playground notification module.
as data souce select the current aquasuite profile.
for each profile you have to build a notification.
in the notification you can set the action for your external application
cmsj
Donnerstag, 5. November 2020, 21:18
That's very interesting, thanks!
