• 15.11.2026, 20:32
Omnipotous
Error trying to install X27 from installer within Aquasuite
Freitag, 6. November 2020, 20:29
i there i get the following error on the latest version of Windows 10 Pro it has all .Net updates to the latest version
the application was unable to start correctly (0xc000007b).click ok to close the application
what am i doing wrong.?
Freitag, 6. November 2020, 23:42
Try the setup from the download section
Omnipotous
Samstag, 7. November 2020, 02:38
exactly the same error
Samstag, 7. November 2020, 10:25
try to install the latest vcredist version
Omnipotous
Freitag, 13. November 2020, 20:28
and where is that as its not on Aqua computer website, i just checked the search option aquasuite_setup.exe is all there is to click on and ive tried that now 3 times no Joy.?
Hufeisen
Freitag, 13. November 2020, 21:30
You can get the latest vcredist from the www.microsoft.com website.
The file you need to download is called vc_redist.x64.exe
You can get it here: https://support.microsoft.com/en-us/help…ual-c-downloads
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hufeisen« (13. November 2020, 21:33)
Omnipotous
Sonntag, 22. November 2020, 14:59
so frustrating i have the microsoft download, yet the aqua computer download .exe gets to 99% and fails every time i have x.26 installed running and working
i have 18 Aqua computer devices logged into X26 and custom pages setup for my system, am i supposed to uninstall it all first then run registry clean up then try reinstalling because i have no confidence on your latest installer to not fail, leaving me with no interface.
windows setup
Edition Windows 10 Pro
Version 20H2
Installed on ‎22/‎08/‎2020
OS build 19042.630
Experience Windows Feature Experience Pack 120.2212.31.0
is there any other information you need to resolve the updating issue
Montag, 23. November 2020, 08:13
?? what is not working. Make Screenshots and describe your problem more precisely.
Omnipotous
Freitag, 27. November 2020, 22:48
this is the 3rd post on the error i did screen shots before and you said to download the Microsoft redist 64bit package i did this same error not fixed
i cannot screen grab the box that appears so i previously wrote it down and posted i get the same error every single time I'm stuck on X.26
super products great software i have mine configured for both colour switching for movies AmbientPX and gaming i also have three settings for Noise level from cooling fans on water blocks.
i can switch all setups in the sandbox with keyboard short cuts
but the install / update just doesn't work
what time are you available i can let you remote View with Teams screen share. or something like that
