• 08.10.2026, 11:18
Syndra
How many pumps for the airplex GIGANT 3360?
Dienstag, 10. November 2020, 18:31
Should I go two or three pump system for a Gigant 3360, CPU, and GPU loop? Will using two pumps means I would have to run the pumps at a higher flow rate?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Syndra« (10. November 2020, 19:18)
Hufeisen
Mittwoch, 11. November 2020, 09:37
What pumps are you using? D5 or Aquastream or DDC?
Syndra
Mittwoch, 23. Dezember 2020, 22:36
I am using D5. I'm just starting to build my computer. Finished installing one single fan at top of the Gigant 3360. I will be getting the last of my computer parts next week or the first full week of January and I need to start buying fittings, pumps, tubing, ect. Any help will be appreciated. I'm also thinking of get a highflow next. How long does Aquacomputer take to restock?
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Syndra« (23. Dezember 2020, 22:40)
Fieldrider
Donnerstag, 24. Dezember 2020, 07:46
I have a DDC1T and I get around 150l/h with one CPU-block, two GPU-blocks, one AMS 840 and one Gigant 3360 in the Loop.
