• 16.11.2026, 07:32
BenCrosby
Config mode for new D5 NEXT pumps (?)...
Donnerstag, 26. November 2020, 03:46
Perhaps I am the only one who has tried to do this, though that surprises me.
I want to set up aqua suite, configure all the RGBpx, build the curves and virtual sensors, and so on, with the devices simply powered and connected to a laptop, before completing the install into my PC.
To achieve this with the pumps, I would expect to be able to configure the pump controllers without the motors attached. Obviously this causes the NEXT to signal a critical alarm, with the incredibly loud and piercing buzzer going continuously, from in my case, two pumps.
I need to do firmware updates and all sorts of things before I am ready to test with water in a loop. Please could you consider some kind of “config” or “maintenance” mode that silences the alarms to allow this to be done?
Cheers.
Ben
Donnerstag, 26. November 2020, 04:49
If you have PWM pumps, perhaps you could substitute a couple PWM fans during the configuration?
BenCrosby
Donnerstag, 26. November 2020, 15:08
I’m specifically referring to the D5 NEXT’s.
https://shop.aquacomputer.de/product_inf…roducts_id=3785
I can’t config those without their controllers plugged in.
Cheers.
Kuminauha
Donnerstag, 26. November 2020, 15:37
Could you just build a loop with a hose from outlet to pump inlet? Shouldn't be too time consuming?
