• 07.10.2026, 18:50
PA3Q
High Flow Next Installation, angled fittings OK?
Freitag, 4. Dezember 2020, 10:07
A basic question I guess, but I am building my first liquid cooled computer.
Should the sensor be installed with a straight line of tubing before and after, for the flow to be accurate?
Or will it work properly with 45 degree/angled fittings before/after the sensor also?
Freitag, 4. Dezember 2020, 10:58
Any turbulence in the flow has an influence on the measurement. An angle in front of the sensor will influence the measurement. By how much is difficult to say.
You can only correct this by comparing the sensor with a reference in your system.
PA3Q
Freitag, 4. Dezember 2020, 11:57
Thank you for the reply.
So, I should probably install the sensor with a couple of centimetres of straight tubing in front and after, to get the most correct measurement.
With 5 out of 10 fittings being 90 degree already, I guess the flow will be drastically lowered.
