• 03.10.2026, 17:08
Freshage
Aqua Computer D5 pump + Aquasuite high rpm
Donnerstag, 31. Dezember 2020, 13:14
Hi all,
Just replaced a EKWB pump (failed) with a trusty Aqua Computer D5, however, even at 1% rpm control, it's at 1800rpm, previously I ran around 1300rpm at 35% min power. Is there any trickery in the software to reduce the rpm?
Thanks
Kuminauha
Donnerstag, 31. Dezember 2020, 14:01
There could be difference in the PWM control of these pumps. If so, the is no easy way to lower the pump speed. In my case, D5 pump is nearly inaudible inside the chassis even at 3300 rpm. It is mounted on EK Revo mount.
My chinese D5 pump runs @ ~1850 rpm at 1% PWM duty cycle.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Kuminauha« (31. Dezember 2020, 14:05)
Freshage
Donnerstag, 31. Dezember 2020, 15:29
Sadly even at 1800rpm, it's still audible (slight motor whine) which is audible over my fans. At least at idle.
