• 03.10.2026, 00:01
kip714
OCTO TEMP WITH RGB
Mittwoch, 13. Januar 2021, 17:14
I know the Fabwerk can use temputure to control rgb. Can the OCTO also use temp to control the rgb lights without the Fabwerk?
Mittwoch, 13. Januar 2021, 18:01
I have a quadro installed atm, probably similar to an octo for RGBpx, and some of the effects (didn't check all) may be controlled by a sensor such, as temperature.
kip714
OCTO TEMP WITH RGB
Mittwoch, 13. Januar 2021, 19:03
So, can you set the rgb to turn red if your set temp is reached? Okay, just looked at your pic. Looks like it does what I want.To bad they are not in stock in the USA. Thanks...
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »kip714« (13. Januar 2021, 19:30)
Mittwoch, 13. Januar 2021, 20:03
The effect you want is named "Color Switch".
It runs color 1 until the sensor exceeds the limit you set, then switches to color 2.
Edit: OCTO's are scarce atm, but you can back-order at ModMyMods, which places you in the que. You can email them for info.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (13. Januar 2021, 20:11)
k2viper
Mittwoch, 13. Januar 2021, 21:22
Not sure about Quadro/Octo RGBpx controllers, but with farbwerk360, "Color switch" effect gradiently changes set colors. Looks very good.
kip714
OCTO TEMP WITH RGB
Mittwoch, 13. Januar 2021, 22:33
Thanks for your help.
Donnerstag, 14. Januar 2021, 04:07
[attach]8017[/attach]
Yes, a quadro also has the Fade, Brightness controls available for those who prefer that.
