• 30.09.2026, 04:52
BubbySoup
Evo 120 question
Mittwoch, 5. Januar 2005, 04:00
I am just about to order my new PC and have decided to watercool it. I am really after silence over o/c but obviously any o/c I can get from the watercooling is a bonus!
What I woud like to know is if the Evo 120 will be good enough to cool my AMD FX55 and perhaps my ATI 850XT-PE. No chipset or hard-drive cooling and maybe not even my graphics card depending on how quiet the fan is when it arrives.
Many thanks!
Bubby
Nitrix
Re: Evo 120 question
Mittwoch, 5. Januar 2005, 10:15
There would be no problem with that at all.
but i would probably recommend buying your own fan the one i got with my order wasent really silent ;)
major23hh
Mittwoch, 5. Januar 2005, 10:59
hey bubbysoup, I would recommend taking a bigger radiator to you, just because an evo 240 has more potential and the fans you are installing can turn on a lower level.
e.g. : an evo 120 mit a papst @ 12V ist powerful enough to cool down your components. An Evo 240 with 2x Papst Fans @ 5V also. Though the second solution is much more quiet, and i think thats one of the biggest advantage of watercooling a system: SILENCE (oops, was this a little bit loud? ;) )
BubbySoup
Mittwoch, 5. Januar 2005, 21:31
Thanks for the replies :)
Nitrix
Donnerstag, 6. Januar 2005, 00:24
no problem we have sent you an invoice ;D
FarEast
Samstag, 15. Januar 2005, 03:16
Many thanks!
Bubby
Actually you'll be fine with the "Evo 120" If you look at this link: http://www.aqua-computer-systeme.de/e_forum-index.htm
You'll see i have the CPU, GPU and Northbridge all been cooled by the Evo-120 the GPU and CPU are overclocked as well and it was still able to keep the temps well below 50 C durring the summer months here in Japan (Ambient tems are around 44C with high humidity).
