• 18.11.2026, 10:33
kip714
Farbwerk and RGBpx
Sonntag, 24. Januar 2021, 01:29
I have a Farbwerk and RGBpx strips. I can't find the correct cable to connect them. I bought a cable that plugs into the Farbwerk but not the RGBpx. Any help would be appreciated.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »kip714« (24. Januar 2021, 01:38)
Sonntag, 24. Januar 2021, 02:09
farbwerk does not do addressable RGBs, you need farbwerk 360 for that, then you can use these cables.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (24. Januar 2021, 02:11)
mditsch
Sonntag, 24. Januar 2021, 07:11
I guess the sentence from infoseeker could be misunderstood..
I think better is: "Farbwerk does not do adressable RGBs like RGBpx.You need...". 8)
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »mditsch« (24. Januar 2021, 07:49)
kip714
Sonntag, 24. Januar 2021, 14:26
Thanks for the info. I'm pretty sure what I read was in English.... and I still didn't understand. My last build has a Aquareo 6XT, Hubby and 2 Splitty 9's. It took awhile to figure that setup out. Just started on my new build, have been out of the buying loop for a couple of years, saw the Farbwerk and bought it. Then of course I saw the Farbwerk 360 and the Octo. Seems like I jumped the gun on the Farbwerk. Again, Thanks for the info...
kip714
Sonntag, 24. Januar 2021, 14:30
Is it possible to connect an Octo and a Quadro in the same system? Or would a Farbwerk 360 and an Octo work. I'm trying to get rpm's and full control over all 11 fans along with temperature sensing RGBpx.
kip714
Sonntag, 24. Januar 2021, 14:53
I see I would have to connect 3 fans together on the Octo and I presume those three fans would only read 1 RPM signal? Can I connect an Octo and a Quadro to read all 11 fan RPM's?
Sonntag, 24. Januar 2021, 17:28
You cannot 'connect' an octo & quadro together, but if you have them both on USB, each will have it's own tab in the aquasuite, and you will have a separate fan controller for each fan port (8+4).
kip714
Sonntag, 24. Januar 2021, 18:09
Thank you Infoseeker. You name should be Infogiver. :) :) .. Now I can order what I need, not what I think I need. :) :)
