• 01.10.2026, 09:35
torexko
high flow NEXT and HWiNFO support
Dienstag, 26. Januar 2021, 17:11
At the current time the high flow NEXT is unfortunately not supported in the HWiNFO software (it is not possible to see any measured values from the sensor inside the HWiNFO software).
Most of the previous Aqua Computer products are already supported, so this should not be a problem.
Martin (creator of HWiNFO) asked me to contact Aqua Computer and kindly ask them to provide him with all the necessary information about the high flow NEXT sensor, so he can integrate it into their HWiNFO software.
The thread can be found here: https://www.hwinfo.com/forum/threads/ac-high-flow-next.6760/
Hopefully some from Aqua Computer will read this and help us, so we can improve the high flow NEXT user experience :)
Dienstag, 26. Januar 2021, 17:21
We know that, but we have so much to do at the moment that we have to do our job first and take care of time consuming things like supporting other software.
The documentation of these interfaces takes time that we need urgently elsewhere.
Dienstag, 26. Januar 2021, 17:32
Actually. HWiFNFO claims support for the High Flow NEXT with the latest release.
I don't have mine running yet, so not sure to what extent.
Quoted from their last update log:
HWiNFO v6.42 available.
Changes:
Improved support of some future AMD CPUs and APUs.
Fixed a possible hang on some systems with Intel Thunderbolt controller.
Enhanced sensor monitoring on ASUS ROG STRIX B550-XE.
Added reporting of DIMM module location if BIOS provides correct data.
Fixed VRM monitoring on ASRock Z490 Taichi and B550 Steel Legend.
Added monitoring of Effective GPU clock on NVIDIA GPUs.
Improved reporting of serial number on NVIDIA GPUs.
Enhanced sensor monitoring on MSI Z590 and B560 series.
Enhanced sensor monitoring on GIGABYTE Z590, B560, H570, Q570 and H510 series.
Added monitoring of Aquacomputer farbwerk 360 and highflow NEXT.
Added fan speed monitoring on some MSI notebooks.
Enhanced sensor monitoring on some ASRock Z590, H570 and B560 series.
Added monitoring of GDDR6X Memory Junction Temperature on NVIDIA RTX 30-series.
torexko
Dienstag, 26. Januar 2021, 18:56
Changes:
I just updated my HWiNFO to the latest version (v6.42) and High Flow NEXT is indeed supported and it is working properly!
Seems like the update was released just a few hours ago. Thank you for the heads up.
mditsch
Dienstag, 26. Januar 2021, 18:57
Changes:
its showing it in hwInfo
