• 30.11.2026, 22:34
Black Falcon
Aquaero 6 pro not reading temp sensor on high flow 2
Mittwoch, 24. Februar 2021, 05:58
I have recently completed a build and am using an aquearo 6 pro along
with a high flow 2 that advertises built in temp sensor. I have the HF2
connected to the 3 pin "flow" connector on the AQ6 and the included
sensor part of the cable connected vertically to the 2 pronged sensor 1
connector. I get a flow reading and the high flow 2 is recognized but no
temp readout. The only temp readouts I can see are the for fan header
temps, don't know what they are but certainly not water temps. Help
would be appreciated, I can see no other way to wire this high flow 2.
It only came with the one cable and I hooked up the two ends in the only
places they would fit.
I have the 3 pin pwm connector connected to "flow" and the 2 pin black connector connected to sensor 1
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Black Falcon« (24. Februar 2021, 06:01)
Mittwoch, 24. Februar 2021, 07:20
Connect a other temperature sensor with your auqaero and check if you aquaero is working.
Black Falcon
Freitag, 26. Februar 2021, 00:53
I need to order another sensor? Can someone tell me what screen the sensor is supposed to show up on at least?
