• 22.11.2026, 03:46
D11125225
Dienstag, 2. März 2021, 14:05
Questions left to be answered
Is there any other ambient temperature sensor other than AQ that is compatible with one of these products (OCTO/Farbwerk/Flow Mps/Pressure Mps)?
In terms of EK Cpu and Gpu blocks, will they work if I hooked them up straight away with farbwerk without any adapters using drgb headers on farbwerk?
Dienstag, 2. März 2021, 15:00
Yes, any 2-pin, 10 kOhm temperature sensor should work
Not sure what you are asking.
The farbwerk 360 uses a PicoBlade system connector and the CPU/GPU blocks do not... unless you solder directly to the pins, you will need an adapter.
