• 22.11.2026, 22:16
onmute
Farbwerk 360 on Aquabus
Samstag, 6. März 2021, 18:48
I cannot seem to get the Farbwerk 360 working over aquabus. My D5 Next shows up just fine. Everything I have been reading is telling me to connect it via USB first, then assign a unique aquabus address. I have done the USB part but cannot find anywhere to set a "unique bus" for it. The settings tab under the farbwerk only allows me to rename the device, usb standby options, and factory reset/firmware upgrade...nothing about a bus ID.
Thanks in advance.
Samstag, 6. März 2021, 19:12
The Farbwerk 360 does not work over the Aquabus, the bus is too narrow-banded for this. The connection at the Farbwerk 360 has no function so far.
onmute
Samstag, 6. März 2021, 20:08
Now that makes perfect sense...thank you for confirming the behavior as normal :).
