• 06.10.2026, 04:08
Silky_
MPS Pressure Sensor Showing no data in Aquaero?????
Dienstag, 6. April 2021, 03:10
Good day to all,
I have installed an MPS Pressure 500 to monitor the pressure across my filter, it shows the data on Aquasuite under the Pressure Sensor tab with an average pressure of 2.1 mbar.
However when I go to the Aquaero tab and go to sensors, and pressure sensors, it shows 0.0 bar all the time.
Is there an adjustment I need to make to show the same data? I am using an Aquaero 6 XT and have the pressure sensor connected to USB and Aquabus.
Thank you for your help. ?( ?( ?( ?( ?(
Dienstag, 6. April 2021, 07:32
No, you can display pressure data.
0.0 bar == 2.1 mbar
0.0021 bar == 2.1 mbar -> aquaero display is correct.
