• 05.10.2026, 20:03
Thomas
OCTO not recognized after software update to version x.38
Freitag, 9. April 2021, 12:06
Hello,
Just updated aquasuite to version x.38 and now my OCTO is not recognized anymore.
I have " remove device from aquasuite" several times. shut down PC, disconnect power, wait for 5 mins and also swapped USB ports.But whenever i try to update the firmware of the OCTO i get the above screen again, really anoying.
I have also tried launching aquasuite as administrator, makes no difference.
I have no other PC's available to perform the updates, any idea's?
Best Regards
Thomas
Thomas
Freitag, 9. April 2021, 12:36
Would not let me edit cause of 10.000 character limit..........
How long does it take for the octo to restart and how i know it restarted? so far i just waited 5 minutes
Freitag, 9. April 2021, 16:12
I believe the aquasuite does not restart itself... you need to restart it.
Thomas
Donnerstag, 24. Juni 2021, 16:50
Ended up disconnecting all fans as well, then update, then reconnect everything. Pain in the behind but got it working again.
Any method of updating to avoid this happening?
Thread can be closed.
Jacob
RE: OCTO not recognized after software update to version x.38
Mittwoch, 14. Juli 2021, 18:23
Sometimes aquaservice will shut down
Device will be disconnected
Just restart the software and connect to the service
device will connect again :)
