• 13.11.2026, 00:24
vulcanrvn90
Is it possible
Sonntag, 11. April 2021, 21:04
Has anyone ever made custom length rgbpx cables? If so where to buy the connector, terminals and punch tool?
Thanks
k2viper
Sonntag, 11. April 2021, 21:40
JST 1,25 4-pin pre-wired connectors on aliexpress. Solder them to any 4-wire cable you need.
cptninc
Sonntag, 11. April 2021, 22:25
Are they JST or Molex Picoblade?
I've made my own using Picoblade components and they work great. The catch is that Molex crimpers are $$ unless you grab some from an auction.
SCANDALOUS
Montag, 12. April 2021, 07:26
I got a 10 pack of pretty crimped Molex Picoblade 10CM for 4€ on Ebay
k2viper
Montag, 12. April 2021, 16:23
Under Molex brand they are called picoblade, but in some places JST 1,25 is the right name for the same thing.
There are pre-crimped with wires.
cptninc
Montag, 12. April 2021, 17:15
JST-SH and Molex Picoblade are not the same thing although they are very similar. The JST-SH is 1.0mm pitch whereas the Picoblade is 1.25mm. For low circuit count plugs, you can usually jam one into the other if you press hard enough. A better option, however, is to just use the correct connector.
k2viper
Montag, 12. April 2021, 22:43
JST 1,25 has exactly 1,25mm pitch and fits perfectly into aquacomputer RGBpx ports.
cptninc
Dienstag, 13. April 2021, 15:46
Do you have a link to that connector handy? I don't see anything mentioned on JST's website.
