• 11.11.2026, 02:57
VolkerInc
3-pin Adapters and splitters
Montag, 12. April 2021, 21:40
I'm currently in the process of building my first loop, and I'm stuck on connectivity issues.
Parts of my setup come from EK, so the RGB cables are 3-pins 5V connectors.
Now I want to control everything from an OCTO, and I know that I'll need an 3-pin -> RGBpx adapter (this one) and an RGBpx cable (this one).
But what if I want to connect all 3 of my aRGB components on one RGBpx connector? Would it work if I use a splitter (such as this EK splitter?), or do I need a FarbWerk before?
Thanks for any answer you can provide!
Hufeisen
Dienstag, 13. April 2021, 17:36
This Splitter works.
But there are a number of Problems, because the Splitter connects the LEDs in parallel. (rgbpx is designed to have a serial connection)
- All connected devices show the same color sequence, because the data is shared. It is no longer possible to address each LED seperately.
- If the connected devices have different amount of LEDs, it will limit or break some color effects.
- In the Aquasuite software, you have to create a dummy effect at the end to match the total numbers of LEDs.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Hufeisen« (13. April 2021, 17:40)
