• 10.10.2026, 04:44
Momonucleosis
Farbwerk 360 + Phanteks ARGB female connectors = bad juju
Freitag, 4. Juni 2021, 06:47
So i've got a ton of Phanteks Halos DIgital, I've got 3 x the phanteks rgb to ARGB extensions / adpater cables, and I swear the connection to the Farbwerk is so loose if you barely touch the cable it will pop off of the Farbwerk.
link to phanteks cables: http://www.phanteks.com/PH-CB_RGB4P.html
Is this normal? ... is it just that all three of these cables are 'loose' fitting? ...
This seems ridiculous how easy it is to disconnect these things. These connectors lacking any kind of clips, should be fitting snug. Right...? They are anything but.
They all work, don't get me wrong... just suuuuuuuper annoying to close up the case without bumping a cable and unplugging on or more of these.
Cheers
Momonucleosis
Freitag, 4. Juni 2021, 06:50
The only solution i can think of... give the pins on the Farbwerk a little tweak/bend, so that there is a bit of friction-fit once inserted.
SaiBork
Freitag, 4. Juni 2021, 08:49
I have the same with my EKWB Pump/res combo. If you look at it, it will come off the farbwerk. I managed to get it placed and it works, but it is super easy to come off.
The LianLi Strimer is also very loose connected, but not as loose.
The EKWB fans seem to be a bit better still.
I think it just depends on how tight the holes of the connectors are as there is nothing really to hold them in place.
Freitag, 4. Juni 2021, 11:28
We are using the same connectors that are mounted to the mainboads. These connectors are not made for this application.
That's why we use PicoBlade connectors for RGBpx.
Momonucleosis
Samstag, 5. Juni 2021, 01:52
Sorry... So the issue is the Farbwerk360's connectors then?
Momonucleosis
Samstag, 5. Juni 2021, 02:47
I just plugged in the front panel cable for my Lian Li 011d xl and the fit is super snug, it almost clicks in, and is what I'd expect. I'm putting this issue down to the phanteks cables being garbage and sloppy as all hell.
EDIT: plugged in one phanteks cable to motherboard. It is far better than plugging it into the Farbwerk, but nowhere near as good as the lianli.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Momonucleosis« (5. Juni 2021, 02:56)
