• 07.10.2026, 14:11
etoel
LEAKSHIELD - coolants from other vendors
Montag, 21. Juni 2021, 09:20
The manual clearly states that only DP Ultra is approved:
To ensure safe operation, only coolants of the DP Ultra series are approved for
use. Even if many other coolants are certainly trouble-free, we cannot guarantee
the function with these coolants
It is fair that you only guarantee DP Ultra, but can you offer some guidance on premixed coolants from say EK? It is hard to understand why they shouldn't work...
Montag, 21. Juni 2021, 09:33
It is always a question of the ingredients of the coolant and how they react to a vacuum.
The leak shield will do its job, regardless of the coolant, but the reactions in the circuit could be problematic.
It is only logical that Aquacomputer does not take any responsibility.
Remayz
Montag, 21. Juni 2021, 12:36
technically that's not even vacuum cleaner levels of vacuum (typically around 200mBar). I don't believe it's worth checking vapour pressure charts yet :p
Should be fine but all manufacturers only guarantee their gear with their coolant because they can't lose time endurance testing with every coolant brand out there.
If you really want to dig into it you'll have to look at EK's cryofuel components, seek the chemicals vapour pressure charts and look how they behave at around 450mbar at the worst temperature possible, which would be around 60°C (the temp limit most pumps are rated at, or PETG's floppy temp)... or just ask them :)
But yea.. 450mbar, i wouldn't sweat it. it's a very light depression in the grand scheme of things.
